C Farmall Block
Captaink
09-08-2004 17:03:26
I have a C with a cracked block. Was there any IH combine power units that utilized the same block as the C? If so, which ones?
Thanks in advance!
Mike@NY
09-08-2004 18:03:39
 Re: C Farmall Block in reply to Captaink, 09-08-2004 17:03:26
There were combine engines that will fit, with some work (others will be able to describe that more). But I would like to ask where and how bad is it cracked? Sometimes they can be fixed. Also, blocks from a Super A, Super C, 100, 130, etc will fit as well (just watch the casting numbers, the later ones used bigger diameter sleeves, and not bore size, if you want to use existing parts). Where are you located? I have a spare block from a Super C that will fit.
captaink
09-09-2004 05:54:31
 Re: C Farmall Block in reply to Mike@NY, 09-08-2004 18:03:39
Mike,
Thanks for the info. I'm in SD. let me know via e-mail how much etc on the block. My e-mail is ck680backhoe@hotmail.com
Thanks
