Update, got my Alternator working
Richard Fazio
09-09-2004 14:41:47
Big John & Steve, thanks a lot I tried connecting to the L terminal on the nippon alternator and I had charge. What I'm thinking is to put the L terminal on with the key. So when I turn on the key it's energized. The main bat terminal is always hot but I don't want to keep the L terminal hot, correct?
Bob
09-09-2004 18:01:18
 Re: Update, got my Alternator working in reply to Richard Fazio, 09-09-2004 14:41:47
I believe it would be best to have an "idiot lite", resistor, or diode in the "L" lead that connects to switched power from the key switch.
Richard Fazio
09-10-2004 03:48:52
 Re: Update, got my Alternator working in reply to Bob, 09-09-2004 18:01:18
You mean to hook up a light between the key and the L terminal? Would the light act as an indicator? On would mean it's working or not?
Loren
09-10-2004 19:03:03
 I was told the L meant light. in reply to Richard Fazio, 09-10-2004 03:48:52
On several import auto alts. there are L terminals, the rebuilder told me that goes to the idiot light to indicate if it's charging.
lee
09-09-2004 21:39:28
Yes, this is the way to do it.
