No spark at points on Farmall H
Red Dread
09-10-2004 17:40:43
I just overhauled the engine on my H and have gone through a tirade of problems which have all been solved. Now I have no spark at the plugs or points. The system has been converted over to 12 volts. I broke the ballast resistor during the rebuild and replaced it. I replaced the points,plugs,condenser,rotor,cap and coil for the second time and still no spark.It seem I have 12 volts to the points with the switch on but it does not spark when you open the points. How do you troubleshoot this?
Nebraska Cowman
09-10-2004 18:45:08
 Re: No spark at points on Farmall H in reply to Red Dread, 09-10-2004 17:40:43
well. first you see if you got juice to the coil. then you unhook the wire from the coil to dist and see if the coil is working, go from there.
Red Dread
09-11-2004 07:48:47
 Re: No spark at points on Farmall H in reply to Nebraska Cowman, 09-10-2004 18:45:08
Problem solved!!! It was the condenser wire grounded to the side of the distributor.
