Farmall MD serial numbers
AdamA
09-10-2004 20:19:40
I know that International made an attempt on some tractors to match the serial number with the number stamped on the engine. My MD has the serial # tag missing. I found the engine number above the injector pump it was FDBKM..... This is th eorginal engine so could this be the tractors serial # also? Thanks, Adam
brianh
09-11-2004 05:46:11
 Re: Farmall MD serial numbers in reply to AdamA, 09-10-2004 20:19:40
No, the engine serial numbers were considerably lower, since they did not make many MDs. Only 18,000+ compared to 280,000+ Ms. You may be able to roughly tell the age from the casting codes though. Brian
