Hydraulic Filter Question on 560
Carp
09-11-2004 17:12:12
I had the wife pick up hyd filters for the 560 and she came back with an oval filter the same size as the screen filter I pulled out of the tractor. It has the right size hole to mount up to the suction side of the pump, but it has a big hole with a gasket on the other side. It is not thick enough to fit tight up against the cover that bolts on. I do not think it is the right one. Part # 388080R93
The filter I pulled out has the 2 small round filters inside the oval screen housing.
On top of that the bill has part # 388084R93.
Do I have the right filter????
Carp
09-12-2004 05:22:43
 Re: Hydraulic Filter Question on 560 in reply to Carp, 09-11-2004 17:12:12
Thanks for the help guys. Does anyone have the part E for the bypass screen and spring?
Novel Idea Guy
09-11-2004 17:38:41
My dad says the filter you took out is the original; it"s likely that it"s never been changed... The filter you have is the correct one. They changed it to a once-piece unit, but you need an extra bit to get it to fit right.
Aces
09-11-2004 17:31:27
Carp That is the kind that came out a long time ago but there is a creen with a spring on it that goes in that big hole, should get better flow with the new kind
Carp
09-11-2004 17:43:08
 Re: Hydraulic Filter Question on 560 in reply to Aces, 09-11-2004 17:31:27
I guess the fella behind the counter prolly figured the filter had been changed since the 70's. Now all I gotta do is get the screen and spring. :(
Looks like I'm down for the rest of the weekend.
Chris Brown
09-11-2004 19:41:16
 Re: Hydraulic Filter Question on 560 in reply to Carp, 09-11-2004 17:43:08
The screen thing they are talking about is a bypass valve for in case the filter gets clogged,it sucks through the screen,it also has a flat spring that holds the whole filter assembly in. I just bought one for about another $12 on top of a new filter. My old one was the old screen type you had.
Duane NC OH
09-12-2004 05:22:49
 Re: Hydraulic Filter Question on 560 in reply to Chris Brown, 09-11-2004 19:41:16
i agree you have the correct part. also wondering what the oil looked like after you drained it. and how many hours are on your tractor. i bought a 686 4 years ago with 2950 hrs on it. the oil was like chocolate milk. i don't think it was ever changed. i have a 560 D also.
good luck!
Duane
