farmall A carb problem
Pete
09-12-2004 14:10:25
I have a 1945 Farmall A ,that was running fine untill I ran out of gas. I fill the tank and made sure there was no trash in the carburator. when I would first start it ,I would choke it and when it would pop of one time then I wouldopen choke then it would start right away. Now it will not start. It does have fire.Any ideas anyone?
gene
09-12-2004 15:51:19
 Re: farmall A carb problem in reply to Pete, 09-12-2004 14:10:25
My guess - float is hung up/stuck. Remove the drain from the bottom of the carburator to see if you have a good fuel flow. No fuel flow - rapp on the side of the carburator. If that doesn't work remove the fuel line from the carbuartor and check the fuel flow.
If you have a good fuel flow comming into the carbuartor but none out the drain you will need to take apart the carburator.
Pete
09-12-2004 18:43:53
 Re: farmall A carb problem in reply to gene, 09-12-2004 15:51:19
already did that .As a matter of fact just put in a new kit
Gene
09-12-2004 21:25:31
 Re: farmall A carb problem in reply to Pete, 09-12-2004 18:43:53
Ouch. If the carburator is ok, then suggest checking the points (point gap) and plugs.
If it was running ok until it ran out of gas - sounds like a fuel problem. Next would be ignition then compression.
Fresh out of ideas.
Gene
