Farmall H Clutch Problems
HogWild
09-13-2004 13:22:00
Put this in Once but it Did not take Just bought a 42 Farmall H For $400 Engine fires up and Runs Great but If I want it to move I have to start it in the Gear I want and shut it off to swicth clutch is non existant what is the problem with it and do I have to split the tractor in oder to fix it. New to the tractor thing hope this sight helps
Wayne Swenson
09-13-2004 19:39:38
 Re: Farmall H Clutch Problems in reply to HogWild, 09-13-2004 13:22:00
You do not have to split the H to replace the clutch. Just remove the belly pump & drive shaft.
rustyfarmall
09-13-2004 15:17:34
So you are saying that it makes no difference whether the clutch pedal is down or up? If that is the case, more than likely the clutch disc has become rusted to the flywheel. Try driving the tractor with the clutch pedal down, and try to make the tractor stop by using the brakes. This will usually work, may take several tries. If that doesn't work, the clutch may be replaced without splitting the tractor, but we can get into that later.
HogWild
09-13-2004 16:22:05
 Re: Farmall H Clutch Problems in reply to rustyfarmall, 09-13-2004 15:17:34
The clutch does not return to orginal position when i push it in it stays in
Stan(VA).
09-14-2004 05:04:40
 Re: Farmall H Clutch Problems in reply to HogWild, 09-13-2004 16:22:05
That is not right. You need the linkage to work right first. Are you feeling any pressure against the pedal as you press it down?
If not, then follow the linkage all the way into the bellhousing and see where it is either disconected or broken or out of adjustment.
If so, but it wasn't returning all the way back to the tranny deck (only comes two/thirds back), I would guess just a broken return spring.
If so, and the pedal returns all the way I would guess a stuck clutch plate like suggested above.
If you feel pressure (or more likely restriction) both ways (down and up), then check for a rusted pivot point on one of the shafts.
I hope some of this helps,
Stan(VA).
Andy Martin
09-13-2004 18:00:12
Try greasing the throwout bearing but you'll probably have to remove the clutch.
