Difference between a 674 and 574 IHC
Yellott Canby
09-13-2004 19:47:49
Hello, I was wondering if anyone new the weight of a 674 diesel as well as a 574. Are these tractors the same except for the horse power rating? Thanks YC
JB2
09-14-2004 16:12:47
 Re: Difference between a 674 and 574 IHC in reply to Yellott Canby, 09-13-2004 19:47:49
Hi, the 574 and 674 Diesel both had the D239 German Diesel but the 674 had larger rear tires 18.4-30 vs 16.9-28 for 574. The 674 could also have a different speed transmission than the 574. We had a 674 without T/A for a short period of time but it had a slow speed transmission and 2nd gear was to slow and 3rd was to fast for our JD corn harvester. Traded it for 684 with T/A. Neighbor had 574 and turned up injection pump so it was putting out 66 HP on dyno same as our 684.
Therefore 674 maybe a little heavier than 574 due to larger tire size.
My 2 cents
JB2
CEB
09-14-2004 07:30:25
They have the same engines and everything else is the pretty much the same. My book shows the same thing, about 200-400 lbs heavier for the 674. I think the difference in HP comes from the RPM rating. 2200 for the 574 and 2400 for the 674.
genep
09-14-2004 07:03:06
since no one has responded I looked at the sites with tractor data and, although vague, it appears the 674 weighs about 200-400# more.
