is it a 2-pointor 3 point
tonm
09-14-2004 04:11:04
what is the difference between a 2-point and a 3-point other than the top link
RayP(MI)
09-14-2004 04:48:52
 Re: is it a 2-pointor 3 point in reply to tonm, 09-14-2004 04:11:04
2Pt is basically a wishbone suspended under the tractor - impliments have matching arms that latch into the back of the wishbone assembly. No top link. True 3pt has two lower arms which are ball and socket at both ends, front attaching to tractor and rear to impliment. Has a top link. There are several devices available to adapt 2pt to 3pt. Either a couple of plug-in arms with balls on the end, plus a top link, or an adapter which slides in to the 2pt, and makes it like a fast hitch 3pt unit. IMHO the 3pt is the better choice, overall, and yup, I've got a 2pt/3pt conversion.
Carp
09-14-2004 09:20:54
 Re: is it a 2-pointor 3 point in reply to RayP(MI), 09-14-2004 04:48:52
I almost agree. 3 point is better if you have 3 point equipment. But if you have or can find the 2 point equipment, it is a much better system in several cases. It is impossible to hook up a plow, blade or mower quicker than you can with the fast hitch.
My only problem is getting all the FH equipment, a problem that I am slowly taking care of.
Allan in NE
09-14-2004 15:01:27
 Re: is it a 2-pointor 3 point in reply to Carp, 09-14-2004 09:20:54
Carp,
The trouble with the 2-point stuff is that you are forever stuck with the little equipment.
Anything bigger than a four row cultivator will not work as it is too heavy and the hitch points at the implement cannot handle the stress.
This is why IH bailed out of the fast hitch design.
Allan
Allan in NE
09-14-2004 04:35:02
Hi,
Just about everything; they are a totally different hitching system.
Allan
