water gauge off of H
farmall boy
09-14-2004 06:35:13
i have a water gauge it was not working so i took it off and put it in a pot of boilling water it only went up to run. what is the problem with my gauge.
SGT K
09-14-2004 18:51:02
 Re: water gauge off of H in reply to farmall boy, 09-14-2004 06:35:13
I had this same problem once, found out my thermostat was stuck open. That's what I would check first.
Good Luck
SGT K
The Red
09-14-2004 10:01:59
Sounds like the thermostat is stuck open or missing. That gauge will barely move off the peg in that situation.
Nebraska Cowman
09-14-2004 07:40:02
nothing is wrong with your gauge. Water boils at 212° at sea level. kerosene tractors were designed to run close to the boiling point. Antifreese boils at a much hotter temp.
justin w
09-14-2004 16:43:24
 Re: water gauge off of H in reply to Nebraska Cowman, 09-14-2004 07:40:02
Like NC says, there is nothing wrong. If your tractor has a pressurized system, the water will boil at a higher actual temperature that 212 degrees (probably in the 220 degree range). This is the reason why you should make sure that the temperature gauge you use on your tractor is matched to the cooling system (pressurized or non-pressurized).
