question for KellyC on painting work tractor
Jimfarmer
09-15-2004 08:18:19
Kelly, was impressed with what you did with the 460. I too would like to give my 300 a "working tractor" quality spruce up, but dont know anything about painting. Can you sorta give a quick step by step on how you did yours? how much old paint did you remove? how did you degrease? what paint did you use? Did you remove anything to paint it? etc etc. Any help would sure be appreciated.
CNKS
09-15-2004 18:33:58
 Re: question for KellyC on painting work tractor in reply to Jimfarmer, 09-15-2004 08:18:19
On the other hand, if you want to spend a LOT of time prepping and painting, read several pages on the paint and bodywork forum on this site. Everything that you probably don't want to know.
Kelly C
09-15-2004 15:46:23
On my 460 I just removed the white side pannels.
Used engine degreaser from the auto parts store. 5 cans of it. Then just washed her good. Had to use a wire brush for stuburn spots.
My 460 was not rusted at all so just had some flaking paint to get off in a few spots. A wire brush works good for this. Also used a wire brush Wile the tractor was drying I took a wire brush on my angle grinder and cleaned up the white pannels.
Got out my $19.99 paint gun and loaded it with thite paint. Thinned it some with IH thinner.
Painted the pannels.
Cleaned the paint gun.
460 was now dry so I tapped the lights and any other things I didnt wat to be red.
My wife had a great idea. She said to use tin foil to cover the steering wheel. Last one I did I tapped it and took for ever. Tin Foil works great for this. Also works good for the fuel bowl.
Another good thing to do. Trace out your wheels in a half moon shape from card board. That way you can hold it over the tire and still paint the wheels.( I didnt do this this time and regret it- got some paint on the tire)
Broke down:
3 hrs cleaning the tractor
2 hrs tapeing
2 hrs painting
equals a tractor you can use and not look like your using junk.
Some will scoff. But thats ok. I dont have a week to prep for paint. I used the tractor the next day. Put a nice rub mark in it from a branch wile brush hoggin and didnt feel bad about it at all.
