Carb Problems on a Farmall C
Jerry Ward
09-15-2004 19:17:41
I’m working on a Farmall C as a favor to someone so I know almost nothing about the tractor. The gas pours out of the air intake side of the carb, so I know at least the float is stuck open. Are there different types of carbs for this tractor and if so how do I tell which one I have? If I call my local NAPA auto-parts store or Tractor Supply Store will they be able to supply a rebuild kit?
Delbert
09-16-2004 08:31:01
 Re: Carb Problems on a Farmall C in reply to Jerry Ward, 09-15-2004 19:17:41
Check the float to make sure it isn,t full of gas. Sometimes they get a hole in them and will cause lots of problems.
Jerry Ward
09-16-2004 09:12:51
 Re: Carb Problems on a Farmall C in reply to Delbert, 09-16-2004 08:31:01
I'll check, but I don't think there has been gas in the tractor for more then a year.
gene
09-15-2004 22:05:11
My I&T manual lists 3 carburators for the C - gas.
Carter UT733S or SA
Marvel Schebler TSX-319
Zenith 161X7-10386
There should be an ID tag on the carburator. You will need the tag numbers. No tag - take the carburator to the NAPA dealer or local auto parts store.
Jerry Ward
09-16-2004 08:22:26
 Re: Carb Problems on a Farmall C in reply to gene, 09-15-2004 22:05:11
I've got the Zenith carb, does it sound like it needs a full rebuild or just cleaing out the float valve?
MagMan
09-16-2004 10:55:07
 Re: Carb Problems on a Farmall C in reply to Jerry Ward, 09-16-2004 08:22:26
Hi Jerry, I can sell that kit to you for $20.00 plus shipping if your interested thats less than $2.00 profit on my part. Abuckmaster147@wmconnect.com Email me for my parts web site I really do have some good prices on tractor parts . JON
gene
09-16-2004 09:43:41
It's a very simple carburator. Suggest that if you are going to take the carburator apart to work on the float - go ahead and clean (dip) the entire carburator and do a rebuild.
Jerry Ward
09-16-2004 12:09:09
 Re: Carb Problems on a Farmall C in reply to gene, 09-16-2004 09:43:41
got the bucket (looks like a gallon paint can) of carb cleaner with the wire basket in it for $15 and Murry's Auto Parts. Whould I soak it overnight or how long? Just throw the whole thing in or take it apart first?
Jerry Ward
09-17-2004 06:14:21
 Re: Carb Problems on a Farmall C in reply to Jerry Ward, 09-16-2004 12:09:09
Well guess what the can has directions on it. No rubber or plastic and 15-30 minutes.
