H Mag seems to be shorted
JonwithanM
09-16-2004 08:37:04
I have a 44 H with a standard (I4?) mag.
when it gets hot it stops sparking. Take the cap off spin the engine no spark. Let it cool completley and it will start again. I have replaced the points and condencer twice but still the same resuld. I recently installed a replacement mag and it works fine.
I am looking for a reccomendation on where to send to have it fixed, someone who can hopefully find this short that only happens when it is hot.
Thank You
Jon
MagMan
09-16-2004 10:47:15
 Re: H Mag seems to be shorted in reply to JonwithanM, 09-16-2004 08:37:04
Hi Jon, If that is a H4 Mag I have coils in stock You have to press the rod out of the old and in to the new and its not always an easy task. I unhid my email if you need anything. JON
MagMan
09-16-2004 10:18:41
Is that a H4 mag? If it is You can send it to me for rebuilding if you want. JON
kfox
09-16-2004 08:54:43
swap the coils and see if the problem follows the coil. It sounds like the coil to me. ken
