M Farmall hydraulics
darrell wilson
09-16-2004 16:36:14
I have got a M FARMALL got this past summer sitting on the tractor on the left side i have 2 hydrauilic outlets one has a hose running to a cylinder for the home made 3 point hitch the other is capped whats this capped outlet for? also a capped outlet on the right side. thanks ahead of time DARRELL
Hermit
09-16-2004 19:51:39
 Re: M Farmall hydraulics in reply to darrell wilson, 09-16-2004 16:36:14
The back, left outlet is the delayed lift outlet.
Nebraska Cowman
09-16-2004 18:11:30
they are all pressure when you pull the lever. In the old days the cultivaters used 3 cylinders. One of the outlets is for delayed lift to raise the back gangs last. I forget which one.
