Farmall coil
Gauger
09-16-2004 19:07:26
Was the original style Farmall ignition coil ever made in a 12 volt version? If so, is there any way to tell 6 volt from 12 volt by appearance?
Gauger
09-17-2004 05:59:53
 Re: Farmall coil in reply to Gauger, 09-16-2004 19:07:26
OK, is there a simple test I can do to determine the voltage
CNKS
09-16-2004 19:33:59
Don't know if you can tell by appearance, I doubt it. OEM Tractor Parts has the original style coil that came on the letter series, etc in both 6 and 12 volt versions -- $44 -- 800-283-2122.
