560 oil filter
darrin
09-17-2004 05:53:12
Anyone know where I can get a kit to convert my
engine oil filter to spin on type?
MN Scott
09-17-2004 20:27:40
 Re: 560 oil filter in reply to darrin, 09-17-2004 05:53:12
Your local CNH dealer has them, about $35.
captaink
09-17-2004 08:55:22
I’m curious as to why you would want to change to a spin-on filter. I had one on a 560 Diesel that I bought and converted it back to the cartridge type because it was such as hassle and mess to change. I may even still have the base for the spin on that was on it. If you are having trouble with it leaking around the top, make sure that the area the bolt goes through is flat, not depressed into the can and has a good copper gasket to seal it. After I got mine good and straight it quit leaking.
Hayshaker5
09-17-2004 06:11:26
I purchased my kit from my local IH dealer. Had trouble with the old one leaking around the top.
