UNUSUAL IGNITION SITUATION
SUPER H
09-17-2004 19:03:34
Just bought a H, checking it over, I noticed that the coil is connected in reverse. Ignition switch to the (-)minus side of the coil and the (+)positive side of the coil to the distributor.
This tractor is a 12v neg. ground. The tractor runs fine and the previous owner stated that he did not have any trouble with it. This seems a little different than what I normally have seen.
What is your take on this situation?
Allan in NE
09-18-2004 05:48:46
 Re: UNUSUAL IGNITION SITUATION in reply to SUPER H, 09-17-2004 19:03:34
Hi Super,
Like Wayne says, just switch 'em around.
Currently, your plugs are firing backwards, which really doesn't mean a whole lot for just putzin' around and that is why the trator seems to be running fine.
But, like you say, the plug should fire from the electrode out to ground instead of the other way around.
Allan
Wayne Swenson
09-17-2004 20:57:23
Just switch the wires on the coil so the "-" is connected to the points. Is this a 12 volt coil or is there a resistor in line to protect the points from premature burning?
SUPER H
09-18-2004 03:03:28
 Re: UNUSUAL IGNITION SITUATION in reply to Wayne Swenson, 09-17-2004 20:57:23
12 VOLT COIL WITH A RESISTOR IN LINE.
