Relining Brake Bands
Gordon
09-18-2004 07:02:05
Is there a company that will reline my H brake bands. And if so what is the cost? 53 dollars seems excessive price for new ones. I used to reline auto brake shoes when I was a teenager and it sure ain't rocket science.
riverbend
09-18-2004 13:02:51
 Re: Relining Brake Bands in reply to Gordon, 09-18-2004 07:02:05
Northeast Brake Equipment in Minneapolis. The cost is about the same as IH. I would avoid aftermarket bands. The backing was not as thick as original and I had three break on me.
Greg
gordon
09-18-2004 13:19:52
 Re: Relining Brake Bands in reply to riverbend, 09-18-2004 13:02:51
Did a google and a yellow pages search for "Northeast Brake Supply" but came up empty. Got contact info for them?
riverbend
09-18-2004 21:16:10
 Re: Relining Brake Bands in reply to gordon, 09-18-2004 13:19:52
612 378 3141
little john
09-18-2004 12:07:47
I found the same. Relining was only $10. less than buying new linings and bands.
John M
09-18-2004 11:03:02
I thought the ame thing,but found out that relining was accually more than new bands,but that was a local shop.Maybe different in your area.
packratt
09-18-2004 11:00:34
You should be able to have it done. I've had the parking brake band for one of my trucks done locally (Richmond, Va) and a friend has had tractor brakes done by the same shop. I also bought religned brakes for a Massey down in Johnson City, TN.
Le
Haas
09-18-2004 19:13:00
 Re: Relining Brake Bands in reply to packratt, 09-18-2004 11:00:34
Was that at Clutch and Brake supply in Johnson City?? I've done business several times there to get old tractor clutch work done as well as brake relining. I've had very good results. I had disk brakes relined. Don't know if they would do the bands.
packratt
09-19-2004 06:08:18
 Re: Relining Brake Bands in reply to Haas, 09-18-2004 19:13:00
That should be the same place. I had drum brake shoes done there. I don"t see why they couldn"t do the band type. I know the one in Richmond was able to do bands.
Le
