power steering on 300 U
Wes in Ohio
09-18-2004 19:37:33
I'm changing my 300 utility from no power to power steering. Is their anything else I need other than the power gear box and safety/regulator valve to make this conversion. Also does the power steering get its fluid from the tractors hydraulics
Dave in BC
09-19-2004 10:39:50
 Re: power steering on 300 U in reply to Wes in Ohio, 09-18-2004 19:37:33
Didn't realize you were converting to PS til I got your email. I sent you a reply with more photos with circles and arrows and descriptions for each one. It's pretty straight forward really.
Unreserved dick
09-19-2004 09:27:29
Other than the tubing to connect things, your shopping list is correct. The original IH setup for factory power steering used the hydraulic system to supply the power steering. You'll need to understand how the hydraulics are plumbed - the power steering variant used external tubing to pipe the high-pressure supply from the safety/regualtor valve to the control valves for the rest of the hydraulics - if you don't plumb this correctly, one or other of these systems (or maybe both) isn't going to work correctly for you.
