Help, My BN runs Rich!
Steve W (NY)
09-19-2004 09:22:30
I have a BN, I've rebuilt the carb, looked it over good, and it still runs rich. The carb adjustment screw does nothing. All the passages are clear, clean, gaskets are in place, float adjusted, etc. What could it be, before I bite the bullet and buy a new one.
Thanks in advance,
Take Care
Steve
jlh
09-19-2004 19:34:32
 Re: Help, My BN runs Rich! in reply to Steve W (NY), 09-19-2004 09:22:30
Check your air breather, as if it is plugged it will also cause this sympton.Good luck!! Jerry.
ffolkes
09-19-2004 10:17:45
The adjustment screw that you are referring to is just to adjust the idle.
Did you get a new bowl to body gasket? I did, and it didn't fit! I had to cut away part of the gasket to allow the float to move freely.
ffolkes
