Broken Wheel - terminal?
David in UT
09-19-2004 11:54:04
Just about finished tearing down a '40 M, go the wheels off, and I found this. The casting is broken, although not on the section that the axle bracket pulls against, so maybe it's ok? Whatcha think? Is this wheel still ok to remount and use or is it only good for practicing some cast welding on?
Thanks,
- David
Dick Davis
09-20-2004 05:40:03
 Re: Broken Wheel - terminal? in reply to David in UT, 09-19-2004 11:54:04
I sure wouldn't mount it.
With the ready availability of replacement wheels at a reasonable costs why would you risk the damage and possible injury of using this one? It might be useful as a weight on an old disk. My nickel Dick Davis
Jim in michigan
09-19-2004 11:59:06
I have two wheels, no clamps,, email if interested in one or both,,,foocenhaber@yahoo.com
