Carb Rebuild - Float Valve Help
Jerry Ward
09-19-2004 16:04:53
Trying to rebuild the carb (Zenith type) on a Farmall C and can't get the float valve seat out. I'm trying to unscrew it and parts of it are starting to break off. How do you guys get it off? Others that I've done, it's been almost 20 years, came out with very little effort. If worse comes to worse can it bill drilled & tapped?
Paul in Mich
09-20-2004 06:32:01
 Re: Carb Rebuild - Float Valve Help in reply to Jerry Ward, 09-19-2004 16:04:53
Jerry, I had the same situation just a week or so ago, and I tried everything from heat to vice grips to sawing a slot to the opposite side of the existing one, but nothing short of drilling the old seat worked. The hole is centered so unless you have distorted the hole, the drill will follow the center. The outer threads of the seat are 3/8 fine, so you can go up to a 5/16 drill size, but I suggest starting out with a drill that will drop into the hole and hand drill through the seat first. Then go up a size and drill incrementally until you get to 5/16. At that point all you should have left is a very thin wall and the threads which you can pick out in just a couple of pieces. The thing to remember and the reason I suggested working up incrementally to the largest size drill is because the seat being brass will cause the drill to grab very easily and snatch the part out of your hand or worse. Its an "easy does it" task, but it worked fine for me with no damage to the top of the carburetor.
MagMan
09-19-2004 16:13:41
Ouch It doesnt have a nut type head to get a socket On? JON
Ol Chief
09-19-2004 18:45:13
 Re: Carb Rebuild - Float Valve Help in reply to MagMan, 09-19-2004 16:13:41
Jerry;It's me again. If you want to try another removal method,go to the ice cream store or supermarket.Buy a small piece of dry ice. (hurry home) Try to keep the base metal warm.Warm water maybe. Then place the dry ice on the seat and freeze it. The brass fitting will shrink and should remove easily.Dry ice is a couple hundred degrees below freezing so watch your fingers.
Jerry Ward
09-19-2004 17:41:49
No, it's got a slot. But since the valve goes up through the center there is only the outer rim wht the slot cut in it for the screwdrive to catch.
Ol Chief
09-19-2004 18:20:45
 Re: Carb Rebuild - Float Valve Help in reply to Jerry Ward, 09-19-2004 17:41:49
Jerry Don't sweat it!If possible get a piece of lead or a soft copper bar.(If you need to anneal the copper,heat it to red hot and plunge it into cold water). It will then be very soft.Then use some sort of common sense means to support the main body of the carb top with out danger of damage.Place the lead of copper on the face of the offending fitting and give light but sharp taps with a small hammer.CAUTION Begin w/ only light blows and work up if needed.Since the valve seat area is well below the surface you will not cause seat damage.After each series of taps try removal.If bar stock lead or copper is not easy to obtain then get some sheet lead and cut several small wafers to place on top of the fitting.This same principle of jarring a tight thread on pipe or fasteners of any sort will work in almost all cases.The exception being that usually a soft cushion is is not necessary.Good Luck.Ol Chief
CNKS
09-19-2004 18:07:02
You will get a new one with your kit, so IF you can get it out without messing up the threads, you will be ok.
Jerry Ward
09-19-2004 18:11:14
 Re: Carb Rebuild - Float Valve Help in reply to CNKS, 09-19-2004 18:07:02
There is a new one in the kit, but how to get the old one out is the question.
CNKS
09-19-2004 18:21:36
 Re: Carb Rebuild - Float Valve Help in reply to Jerry Ward, 09-19-2004 18:11:14
I almost said vice grips, but since that is brass, you can destroy it pretty easy. Then you will have to very carefully drill it out -- don't ask me to do it for you!
Jerry Ward
09-20-2004 15:52:26
 Re: Carb Rebuild - Float Valve Help in reply to CNKS, 09-19-2004 18:21:36
A shot of Penatrating oil (PB Blaster) over night and a bigger screwdriver did the trick.
