560 under seat hydraulic line repair
Kevin Kostiuk
09-19-2004 17:20:40
The steel lines under the seat have a hole in them. They appear to have rusted through. Are there any easy fixes for this? Are the lines available? Thanks for any help.
Leonard Cottom
09-20-2004 19:33:11
 Re: 560 under seat hydraulic line repair in reply to Kevin Kostiuk, 09-19-2004 17:20:40
I have a friend who made replacement lines for both lines for his 460. It took a lot of time and work.
Tom Graham
09-20-2004 17:42:31
I have brazed them with success. I have also used the compression fitting/hose conversion. I got it from local IH parts dept.
El Toro
09-20-2004 13:59:27
Hi Kevin, I would switch to hydraulic hose too.
Hal
Indiana Dan
09-19-2004 20:33:59
Friend,I have traveled this road. I think the tubing is 5/8". A hyd. shop can get you compression fittings and sell you some tubing. I put in new tubing between the block under the seat to just in front of the seat. Had to enlarge the opening at the front of the seat base. As most hand benders only go to 1/2", I had to borrow a bigger bender. Turned out real nice, but the hose idea that was posted here sounds alot easier. Good Luck.
Alvin NE WI
09-19-2004 19:18:03
I used hydraulic hose about 25 years ago, still using it.
Nebraska Cowman
09-19-2004 17:31:12
I've fixed lots of them in the old days by brazing in a patch
Chris Brown
09-19-2004 17:54:08
 Re: 560 under seat hydraulic line repair in reply to Nebraska Cowman, 09-19-2004 17:31:12
Same here,but mine were so bad I had to cut out a piece and braze in a piece of pipe.
Ol Chief
09-19-2004 17:44:21
I agree w/ Nebraska Cowman. Can't think of a more positive and simple repair method.
