560 Help
mme2424
09-19-2004 17:56:31
I have a 560 gas that runs rough and stalls under load, running up a hill, etc. I have replaced the plugs, points, cond, coil with no effect. The dist cap is new. There is an in-line fuel filter from denny"s carb shop that I replaced the sed bowl with and I have cleaned the filter. When I give it gas it wants to stall and it seems like it is not firing on all cylinders. I know this sounds like a fuel/carb problem however any suggestions on what I should try next?
CNKS
09-19-2004 18:16:24
 Re: 560 Help in reply to mme2424, 09-19-2004 17:56:31
I have heard of people successfully using inline filters, and I have also heard of them not providing enough fuel flow. The best setup is a clean tank and a sediment bowl. Your carb probably needs to be soaked in carb cleaner, and at a minimum, a new needle and seat, plus gaskets. I think Case-IH makes you order individual parts as opposed to a kit -- at least they did with my 460. Perhaps other suppliers have a kit. The correct adjustment for the needle for the main jet on your carb is 5 turns off the seat, if it is like my Super H and 460. It can be turned in for better fuel economy, but if you adjust it so it just runs smooth as you do on the H, M, etc, it will do as you have described.
