Re: What is this 1066 worth?
Hayne D. Matthe
09-19-2004 19:03:38
I guess that is a high/low, there was no decal or anything to say what it was, it looked like the same lever as a TA lever, but on the right side of the steering wheel.
Could you shift from low to high and high to low as you were moving, or did you shift it while standing still?
It was parked about 3 years ago under a shed, it was running and everything worked good, has a frontend loader on the front. It was used at a cotton gin to pull trailers and spread gin trash, no heavy pulling, tach has a little over 1,500 hrs.
What's it worth?
Allan in NE
09-20-2004 14:29:07
 Re: What is this 1066 worth? in reply to Hayne D. Matthews, 09-19-2004 19:03:38
Hayne,
Yes, that lever over on the right is the Hi-Lo "Range" control.
1500 hours? You sure?
If I was absolutely positive on the hours, I'd easily go $10K to $15K on the thing.
You sure about those hours? You sure it isn't 15,000 hours?
Allan
Hayne D. Matthews
09-20-2004 15:17:40
 Re: What is this 1066 worth? in reply to Allan in NE, 09-20-2004 14:29:07
I am sure on the hours, the tractor was only used 3 months out of the year, every so often during the summer.
