Super A ammeter...shunted??
RickySa
09-20-2004 06:58:26
I need to replace my ammeter (it passes current, but the needle doesn"t move). It"s a Stuart Warner 60-0-60...I"m not sure if it is original or even the correct gauge. When trying to order a replacement, the salesman asked if it was shunted...I have no clue! The leads off the ammeter go to the starter and voltage regulator (manual calls it a relay...has four leads...two to generator, one to ammeter, one to starter switch). I"ve got a three position light switch (no charging positions )Any info is most appreciated!
Bus Driver
09-20-2004 18:15:24
 Re: Super A ammeter...shunted?? in reply to RickySa, 09-20-2004 06:58:26
The basic meter movement is a milliammeter- responds to just thousandths of an ampere. The built-in shunt sends most of the current around the meter- bypasses it- so that the meter is not ruined by high amperage. Maybe your meter movement has failed and the shunt is still intact. Replace the whole thing.
Bob M
09-20-2004 07:27:41
The original ammeter is "self shunted", ie. it does not have an external shunt and separate wiring between the shunt and the meter head.
Unless your Super A has an alternator conversion, recommend you replace the ammeter a 20-0-20 ammeter. Reason is the stock 6 volt system never throws more than about 12 amps thru the ammeter which may not even cause the needle to deflect on a cheap 60-0-60 ammeter.
Allan in NE
09-20-2004 07:05:58
Ricky,
I think all ampmeters are shunted aren't they?
Allan
Allan in NE
09-20-2004 07:17:28
 Re: Super A ammeter...shunted?? in reply to Allan in NE, 09-20-2004 07:05:58
Besides,
If the thing still passes current, that's a pretty good indicator that the juice is getting around that gauge circuit somehow. :>)
Just guessin',
Allan
