Crankcase Breather and Oil Filler Cap/ Dip Stick
Bill form Senec
09-20-2004 15:21:25
Hi, Does anybody know a site where I can buy a new crankcase breather oil filler cap for a 1948 Farmall cub??? My manual says you can repack the oil filler cap with aluminum crimp filler. Does anyone know where to get this ??? I have a little smoke coming out of my breather cap is this normal??? Will this reduce the smoke that is coming out of the breather cap. Thanks Bill
Farmer Bob
09-20-2004 22:17:46
 Re: Crankcase Breather and Oil Filler Cap/ Dip Sti in reply to Bill form Seneca,IL, 09-20-2004 15:21:25
Bill,
The aluminum crimp material is the same that is used in kitchen range hood filters. These can be found at box stores like Homer Despot or Lowes. I cut them into 2"x6" strips, crumple them up into a rope shape and feed it into the inside of the breather cap and use an old coat hanger with a 1/2" horseshoe like hook on the end of it to help push it down and around the shoulder of the breather cap. Another substance that can be used is a copper pot scrubber available at most groceries or WallyWorld. With either make sure you don't loose any down the filler pipe. This won't eliminate the smoke.
CNKS
09-20-2004 18:55:02
I don't know a source, that does not mean there isn't one. If it were mine I would just soak it in parts cleaner and use it. A little smoke is "normal", a lot of smoke means you have blow-by, not necessarily a problem unless it uses a lot of oil. Fumes and vapors are supposed to exit form that vent.
