farmall super a casting numbers
farmalla
09-20-2004 17:49:49
can anyone tell me if a engine casting number 354898-R2 will work in a tractor that has a 251069-R1
Stan(VA).
09-20-2004 20:12:25
 Re: farmall super a casting numbers in reply to farmalla, 09-20-2004 17:49:49
Yes, it will work and everything will interchange except the sleeves & pistons. If you need them, order a 3-1/4" overbore kit for a Super C; but if you are still running w/o a water pump, spec an early (C113) head gasket to get the large water port openings. Your SA must be a '51 or earlier with that block. The R2 block is just the 2nd rev of the block introduced in '51 for the SC and late SA's. I have an R2 block that came from a '54 SC. I'm not sure when R2 was introduced, wild guess is maybe '53? If you want to chase it down further, post the casting date code and/or the serial number from the block.
Stan(VA).
Hugh MacKay
09-20-2004 19:28:07
Not familiar with the 251069 R1 or 354898 R2. My Super A has 354898 R1. If engines both came from A, SA, 100 or 130 they will bolt up and work with at most minor modifications.
