Order Farmall Cub Parts Online
Red Cub engine swap
Buddy Woodson
09-21-2004 04:54:59
Has anyone out there put a 154 Cub lowboy engine in a red cub? I need to know what will work and what will have to be changed. Thanks for your help.
George Willer
09-21-2004 12:27:12
 Re: Red Cub engine swap in reply to Buddy Woodson, 09-21-2004 04:54:59
That's a project that's high on the list. The 154 engine is in the shop on a stand and the '48 Cub is waiting paitiently just outside the shop.
Unfortunately, the '48 was not running when I got it, so I don't know the condition of the drive train.
I expect the engine swap will be pretty simple. Change flywheel, front pulley, and manifold, and everything else should be the same... except for a slight increase in power due to the higher RPM.
George Willer
Novel Idea Guy
09-21-2004 08:43:55
It should be a pretty simple exercise if you have the original red Cub engine for a visual aid, and for parts. Just take everything off the 154 engine that isn't on the red Cub's engine, and put everything from the red Cub's engine on the 154 engine.
Jim Becker
09-21-2004 05:24:23
On front: crank pulley, generator, I think the fan.
On back: flyhweel.
Other: some exhaust parts.
Maybe some other things I'm not thinking of right now, but those are the main items.
