Farmall 100 gas tank help needed please
goatkeeper
09-22-2004 05:31:36
Hi, Gas tank beyond repair! Will any other models interchange with the 100? There are A, M, etc. on Ebay for sale, but not sure if they are the same. Any good sources for reproduction tanks or good used tanks? Thanks for the help!!!
Jimmy
goatkeeper
09-23-2004 07:44:40
 Re: Farmall 100 gas tank help needed please in reply to goatkeeper, 09-22-2004 05:31:36
Thanks for the info!
Stan(VA).
09-22-2004 11:56:41
You can use an original tank from a Super C, Super A-1, 100, 200, 130, or 140. Be aware that later replacement tanks started coming in a shorter, generic fit configuration that would fit a 230, and the early (A, B, C, and Super A) models, but required a pair of optional triangular shaped brackets on the rear mounts to make up for the 1-1/4" height difference when used on the later models. The front mount bolts on and has two sets of holes to handle either case. It was considered a 'will fit' replacement for the A and B as the fuel outlet was moved to the new (forward) position.
Stan(VA).
Novel Idea Guy
09-22-2004 11:02:55
The 100 is basically a Super A with a different hood and grille. I believe the tanks are the same on both.
rustyfarmall
09-22-2004 08:36:15
H and M tamks are much larger, either of those will not work for you. I don't know about the C, but imagine it also would be too large.
Brian in NY
09-22-2004 05:52:50
My dad has a Farmall B and put a tank from a 100 on it, it worked fine but doesn't look exactly right, I don't know if maybe the tank was a repro or something....he bought it from a neighbor whose 100 partially burned in a barn fire. So I think you should be ok with a B or A tank, but I think the C,H,M tanks are different.
That one on ebay for $10 looks pretty good to me, if it doesn't fit you could re-sell it..
MM_TX
09-23-2004 21:44:31
 Re: Farmall 100 gas tank help needed please in reply to Brian in NY, 09-22-2004 05:52:50
Super C & 200 have about an inch taller bracket than A, B & C tanks. Probably Super A & 100 does also.
