Serial # problem
Dale Furman
09-22-2004 13:01:51
I have a farmall, with serial # J, underneath it is 1540. I just cant indentify this with any serial # 's listed. Please give some help if possible. Thks
Stan(VA).
09-22-2004 13:45:20
 Re: Serial # problem in reply to Dale Furman, 09-22-2004 13:01:51
Your serial number will be on the line ahead of the J. It's probably just very faint. The 1540 is the engine high idle RPM.
Stan(VA).
Dale Furman
09-22-2004 14:20:25
 Re: Serial # problem in reply to Stan(VA)., 09-22-2004 13:45:20
Found serial # very faint, FAA 343283J. is this a super A?
Hugh MacKay
09-22-2004 17:38:52
 Re: Serial # problem in reply to Dale Furman, 09-22-2004 14:20:25
Dale: With your serial number, go to Reasearch & Info, click on serial numbers, then Farmall, and finally Super A. Alway nice to know how this is done. The J stands for Rockford clutch. That Super A was probably one of the first to get a Rockford clutch. My Super A is serial number 336977, and it did not come new with Rockford clutch. I have since changed it.
little john
09-22-2004 15:18:39
best I can tell from the serial numbers page (on the left under Research & Info), it would be a 1953 Super A.
