6v alternator
mwkellner
09-22-2004 18:43:04
jcwhitney only has 6v NEG ground alternators. is there a good place to find a 6v alternator that is pos ground? thanks alot.
Jim Broughton
09-22-2004 22:08:21
 Re: 6v alternator in reply to mwkellner, 09-22-2004 18:43:04
Kellner; Wait a minute, if your rig is an older IH or Farmall, it should be negative ground to start with....so a negative alternator should work just fine. LOL Jim
Allan in NE
09-23-2004 04:02:12
 Re: 6v alternator in reply to Jim Broughton, 09-22-2004 22:08:21
Jim,
I know you didn't mean that, did you? :>)
Allan
gene b
09-23-2004 01:56:49
All letter series were positive ground.
Doug in OR
09-22-2004 20:49:05
Why not just convert the tractor to negative ground? It would be about as easy as reversing the battery leads, reversing the ammeter leads, and reversing the coil connections. After doing this, install your negative ground alternator. You will never know the difference.
Bob
09-22-2004 20:17:04
If you have a good local mom-and-pop automotive electrical shop, chances are they can fix you up way cheaper than $125.00.
Duner Wi
09-22-2004 19:08:08
Yes there is. Antique Auto Battery 800 426 7580 in Ohio. Comes with choice of pulleys. $125.00 plus shipping. I have no connection with this out fit.
