Farmall A radiator cap question
Andrew Z
09-22-2004 19:18:07
I was out tedding with the "A" today and there was some coolant coming out of the cap.( I think I put to much collant in to, about 1" form the top of the fill??) The cap is a regular fuel cap thats on there now. What kind of cap are is the correct one to use?
Thanks for the help Andrew
Haas
09-23-2004 18:36:34
 Re: Farmall A radiator cap question in reply to Andrew Z, 09-22-2004 19:18:07
Radiator caps are readily available for these radiators. Check with one of the vendor sites on the side bar. The A is not pressurized, thermosyphon (no water pump). If too full, the excess will just go out the overflow.
gene b
09-23-2004 01:53:36
Are you sure the overflow tube is not plugged?
CNKS
09-22-2004 19:38:38
It's not pressurized, so it doesn't matter, coolant will find the right level. If your cooling system is plugged, it will lose more, though.
