Ok IH Mechanics,,,,,
ChadS
09-23-2004 07:53:52
Got a strange question,,,, I am building a Hydrostatic steering system for my IH 460 puller, I got an entire steering system from a IH 403 combine, which is fully hydrostaic on the steering. Question is,,, how much hydralic line pressure, does this set up use? I have pictures so you can uderstand what I am doing,, but I need to find a pump that will handle the system. Maybe a Chevrolet? ChadS
Buzzman72
09-24-2004 06:01:51
 Re: Pullin' Tractor Steerin' in reply to ChadS, 09-23-2004 07:53:52
The way I understand the concept of steerin' a pullin' tractor, it goes like this: Left brake = left turn; right brake = right turn, and the steerin' wheel is just somethin' for the driver to hold onto as he's sh*ttin' his pants while the front end comes up way too fast.
So...did I get it right?
ChadS
09-24-2004 07:06:39
 Re: Pullin' Tractor Steerin' in reply to Buzzman72, 09-24-2004 06:01:51
LOL! That is why there is DEPENDS!!! HE HE!! Yeah, sometimes, the front is off the ground, and steer it with the brakes,, but, I gotta drive it up to the starting line. I like Allen's explanation!! That is the truth! Hopefuly, this does not break on me. In pulling, there is alot of cobbling for lite weight parts. Just dont use a JD part on the IH, so it dont break!! LOL!! Another reason i am doing this,, is because the parts that I am using,, comes from IH technology, 100% IH on this puller, no other colored parts on this one. I saved about 60+lbs with these parts VS the conventional rack and pinion, and steering rods. I just wanted to say thanks to this forum. I looked all through my books on the 403, and could not find any info on what I seeked, So, I asked the folks who knew IH!! Thank you all ya IH mechanics!! ChadS
Allan in NE
09-24-2004 07:27:54
 Re: Pullin' Tractor Steerin' in reply to ChadS, 09-24-2004 07:06:39
Chadd,
As long as ya know that I was just a funnin' with ya.
A lot of time I will be jokin' around and people think I'm serious & really get torqued off at me 'cause I'm such a clod-head....
That's the trouble with these darned computers! Ya just never know. :>)
Allan
ChadS
09-24-2004 07:35:04
 Re: Pullin' Tractor Steerin' in reply to Allan in NE, 09-24-2004 07:27:54
third party image
I know! LOL! No harm. Here it is!! my 460.
Ron in Nebr
09-23-2004 20:03:53
 Re: Ok IH Mechanics,,,,, in reply to ChadS, 09-23-2004 07:53:52
Just a wild idea here and probably isn't really applicable, but, if you could spin it fast enough, why not mount your power steering pump out back and drive it off the pto shaft? I'm pretty sure tractor pullers go to great lengths to take weight off the front of tractors and get more weight on the rear.... We do this on our dirt track stock cars- the oil, powersteering, and fuel pumps are all driven off the back of the bellhousing in an attempt to put more weight on the rear wheels(ie-traction). Ok, go ahead and laugh! :)
Jack in Fla
09-23-2004 12:00:07
Chads, I put a perkins Diesel motor into my 3/4 ford pick up. Had hyd steering pump built to fit motor. It started blowing hoses ,steering boxes, ( destroyed, at any where) and hydroboost brake unit. I went to Ford and they told me the pressure on steering box and hydro, was 1800-2000 lbs. Pump was delivering up to 10,000 lbs, and pump man sold me a inline pressure relief valve, and I adjusted to 1900 lbs and hve never had another problem with it. It steers good, and will stop to. This truck is a home built 6x6, F-250 10 wheeler, to pull my tractors with. Jack
Wondering
09-23-2004 19:12:19
 Re: Ok IH Mechanics,,,,, in reply to Jack in Fla, 09-23-2004 12:00:07
What size Perkins did you use? What trany? Sounds like a beast!
Jaker
09-23-2004 15:46:33
Jack,
If you don't mind could you e-mail me, I would be interested in your perkins swap into a ford truck. I have thought about doing it in an older ford and would like to talk with someone that has done it. thanks Jake
lee
09-23-2004 10:54:16
I have no experience with it but if the steering cylinders are large there could be a problem with the flow rate delivered by a vehicle pump. Just something to keep in mind.
Aces
09-23-2004 10:45:33
Chad why not use the power steering pump on the tractor I thing the 460-560 run about 1200 PSI
ChadS
09-23-2004 12:51:36
 Re: Ok IH Mechanics,,,,, in reply to Aces, 09-23-2004 10:45:33
I was going to use the original hyd pump off the combine, it bolts on to the side of the timing cover on the engine. I cant do this, because I swapped the timing covers, from the combine, to the tractor. so, lost the place to mount the pump. I do have room for a auto power steering pump, on the engine, just curious if it would have enough pressure to run it properly. This tractor has no hydraulics on it whatsoever, the only hydraulics it will have is the steering. Thanks fellas!! I appreciate the info very much!! Same as the 706???? interesting,,,, ChadS
Bob
09-23-2004 10:13:41
The 403 hydrostatic steering system is about the same as a tractor system, say a 706. I recall the steering pressure relief on a 706 is set in the 1200 to 1400 PSI range. Perhaps someone will post the exact figure before I get to the shop to look it up. That would be above most vehicle PS pump pressures, but a vehicle pump would probably work just fine (unless it needs to steer with A LOT of weight on the front wheels). It may be possible to set the relief pressure up a bit on a vehicle pump, also, for this kind of application.
Dick Davis
09-23-2004 15:52:08
 Re: Ok IH Mechanics,,,,, in reply to Bob, 09-23-2004 10:13:41
Chad is steering really needed on a puller? Don't you guys just go straight ahead? LOL Dick
K.B.-826
09-23-2004 18:39:00
 Re: Ok IH Mechanics,,,,, in reply to Dick Davis, 09-23-2004 15:52:08
I was wondering the same thing... Half the time their front ends aren't even on the ground!
Allan in NE
09-23-2004 16:12:21
Dick,
Yes, but in the majority of instances, those hot-rodded, cobbled up old heifers will break down half way down the track. Let's face it, longevity just is not their long suit.
So, at that point, it is much easier on the embarrassed owner to quickly turn and steer out of sight as soon as is humanly possible.
This is why we need the power steering. :>)
Allan
