OIL pressure on rebuilt motor
Bill from Senec
09-23-2004 17:24:27
Hi, I rebuilt the motor on a 1948 Farmall Cub but I did not do a valve job on the head. The tractor runs great and does not smoke. The problem is, the oil pressure starts out high on the gauge and after mowing for awhile the oil pressure drops about halfway and if I keep running it, it drops even more. Would a new valve job help or would a new oil pump make a difference? Any help would be appreciated. Thanks, Bill
Shaggy
09-23-2004 19:47:01
 Re: OIL pressure on rebuilt motor in reply to Bill from Seneca ,IL, 09-23-2004 17:24:27
Hey Bill I live in Ottawa IL. just down the road from you. If I can help out let me know. The only cub I have had apart had the oil pump on the back of the block. Once I primed it ( after a rebuild) it ran great!
Bob Quale
09-23-2004 19:25:43
Bill,
I just went threw the same thing on my w4. Turned out to be the oil pump. I had a hard time getting a new pump but finally did. Look at he pump closely!! If I can help let me know.
Bob
Allan in NE
09-23-2004 17:41:16
Hi Bill,
For the most part, oil pressure is determined by pump, crank bearings, camshaft bearings and their connecting passages.
Doubt if your head workings has much to do with the pressure issue unless you have a massive leak at a feeder line or some such thing. But, that would probably show up cold as well as hot
Now, in reality, an engine really only needs about 8 lbs of true oil pressure to operate without eating itself up, but we always like to see 'er up there around 30lbs or so when hot.
Some manuals will tell you that bearing oil clearance can be considered "okay" if it is as high as .003"; some of these young hot rodders even run their engines with a clearance of .005".
I always set mine right at .0015" (minimum clearance is considered by most builders to be at no less than an absolute .001"). Never had an oil pressure issue yet and I've built a trainload of engines.
Just my view,
Allan
CNKS
09-23-2004 17:29:05
Could be the oil pump, worn bearings will cause the same thing. Valve job--no.
