2606 Diesel wont start
Joe Bard
09-23-2004 17:53:18
I have a '69 2606 IH - 6 cyl diesel. Went to start it today after its been sitting for 6 months. Turned right over, but no start. Fuel is clean, its getting to the pump, but not to the injectors.
I had pulled the fuel filters - everything looked ok. Bled them off - I cracked a injector line and nothing at all comes out. Closed it up and tried another. Nothing. Did the pump crap out? Anybody have any ideas? We have had the old girl for many years - first time she has never started.
Thank you!
Aces
09-23-2004 18:34:28
 Re: 2606 Diesel wont start in reply to Joe Bard, 09-23-2004 17:53:18
Joe Maybe the charge pump is not charging the injector pump should be a pressure regulator valve on the charge pump. Then the injector pump has a delievery valve if it is stuck it will not start. If you are not geting fuel to the injectors forget the glow plugs until you get fuel.
