Oil Pan 1954 Farmall Super MTA
Ron Smith
09-24-2004 16:46:42
Went to change the oil in the M and the plug twisted out of the pan with the surrounding metal. So, I am stuck for now. Can rings/threads be welded back on to the pan? Looks like, if I took the pan off and flattened the hold, I might be able to weld it back into place. Anybody have a good way for fixing this problem? Is there a drain cock available that I could fit into the hole? Can a guy buy a used oil pan with a plug in it somewhere? Thanks.
randy hall
09-24-2004 20:18:06
 Re: Oil Pan 1954 Farmall Super MTA in reply to Ron Smith, 09-24-2004 16:46:42
i had this happen to one of my supermta's and i took the oilpan off and brazed the nipple for the plug back in it.
K.B.-826
09-24-2004 19:39:21
Should be fixable. I've seen an oil pan brazed all around the drain plug like someone had the same thing happen.
champspa
09-24-2004 17:25:42
cut a pipe coupling in half put the plug in it loose put argon in the crankcase and heliarc the coupling in place , the argon will prevent any fire .
Nebraska Cowman
09-24-2004 17:19:08
My first thought would be take a black pipe copler and cut it in half. Weld a new floor in your pan. Might be theaded inserts better than the coupler you just have to shop around and scratch your head.
