light switch conections on 1942 H
JRB IN MAINE
09-24-2004 17:34:24
I got a new volt meter today and hooked it up and I ran a new wire from the L side of the regulator to the switch . the old hook up went from the switch to the right side volt meter .Hooked up that way the volt meter shows discharge and if hooked from L side of regulator it shouldn"t There is another coil conection at the bottom of the switch that I dont no where it hooks to.when I restored and rewired the tractor the wires were all striped bare and conections were rotted off so I dont know were it hooks to. well sence my hook up I have found the coil at the top smokes if you only put the switch for just headlights but dosen"t if all lights are on . is that missing conection a ground or that . that do you think ?
have no digriam to go by when I wired the tractor I used a digriam to a farmall c manaul. the H manaul I have dosen"t show anything. does anyone out there know ? Thanks Jeff
gene b
09-25-2004 02:04:54
 Re: light switch conections on 1942 H in reply to JRB IN MAINE , 09-24-2004 17:34:24
Dont you mean AMMETER instead of VOLTMETER as the two are not the same.
JRB IN MAINE
09-25-2004 05:08:47
 Re: light switch conections on 1942 H in reply to gene b, 09-25-2004 02:04:54
the gauge I took of on the tractor clearly marked volts . replaced with amp gauge.
pette ellis
09-24-2004 18:50:09
send me your E mail address and I will send you the wiring diagram
Pete Ellis, Scarboro
Pete1@rec.cnchost.com
daniel gilespie
09-25-2004 04:21:10
 Re: light switch conections on 1942 H in reply to pette ellis, 09-24-2004 18:50:09
Hey i'm in the process of wiring one my self, could i get a copy of that diagram from you my email is farmkid16_2002@yahoo.com
thanks
JRB IN MAINE
09-25-2004 05:16:09
 Re: light switch conections on 1942 H in reply to daniel gilespie, 09-25-2004 04:21:10
Will if I see anything Email havent as of yet.
would be happy to help you out.
JRB IN MAINE
09-24-2004 19:36:35
sent email to address hopefully you get it let me know if you dont .
