Super M sleeve question
Centaur Nut
09-24-2004 18:45:52
I bought some 4 inch sleeves & pistons from Ebay for my Super MTA. The pistons are the same as my old ones but the outside diameter of the new sleeves is a lot smaller. My old sleeve walls are about an 1/8 inch thick and the new ones are maybe a 1/16 thick. Whats going on? Anybody got a part no. for the right sleeve? Thanks, Rick.
rustyfarmall
09-24-2004 18:57:37
 Re: Super M sleeve question in reply to Centaur Nut, 09-24-2004 18:45:52
What you recieved is an "overbore" sleeve and piston set for a Farmall M, not a super M. The standard bore size for an M is 3 7/8", using the overbore kit, you could install 4" pistons, giving it the same horsepower as the later Super M, except the super M had 4" pistons to begin with, and could be equipped with an overbore kit which would allow 4 1/8" pistons.
Centaur Nut
09-24-2004 20:27:20
 Re: Super M sleeve question in reply to rustyfarmall, 09-24-2004 18:57:37
That explains why the new pistons didn't have any markings on them like the factory ones did. So I just need a standard 4 in. sleeve for a Super M. Thanksfor the info!
Oklahomatractorrebuilder
09-24-2004 23:34:56
 Re: Super M sleeve question in reply to Centaur Nut, 09-24-2004 20:27:20
Since you have the overbore kit for a regular M and need a set for a SM, would you be interested in selling the ones you have? Tim
Centaur Nut
09-25-2004 06:38:35
 Re: Super M sleeve question in reply to Oklahomatractorrebuilder, 09-24-2004 23:34:56
I sure would! The sleeves look great, with very little wear. Pistons look good, good rod bearings, no rings, email me if you're interested. I was gonna put 'em back on Ebay but I'd much rather help somebody out here since ya'll have helped so much!
Centaur Nut
09-25-2004 10:41:34
 Re: Super M sleeve question in reply to Centaur Nut, 09-25-2004 06:38:35
Forgot the Email address. Guess my stupid pill is working!
Centaur Nut
09-25-2004 10:47:06
 Re: Super M sleeve question in reply to Centaur Nut, 09-25-2004 10:41:34
I guess Kim is hiding my address. It's Fourmilemorgans@outdrs.net Please put Hey C-nut or something I'd recognize in the subject line.
Hayfarmer
09-24-2004 21:50:20
Or a 4 1/8 overbore sleeve set for super M
