Farmall H lights hookup
Farm w/Junk
09-25-2004 06:49:27
Hi I redid the wiring on my 1946 H this summer and the front lights dont work. The back light works but niether front. Which hookup do I put the front lights on? Thanks
Matt
Wayne Swenson
09-25-2004 20:45:26
 Re: Farmall H lights hookup in reply to Farm w/Junk, 09-25-2004 06:49:27
Be sure to check the grounding of the front lights. The cross piece is clamped the the steering post which in turn is bolted to the transmission cover, etc. Use a test light to see if you have power at the front light wires and be sure the test light is grounded when using it.
I always recommend testing or verifying the problem before trying to fix something that is already working!
Farmer Bob
09-25-2004 08:08:49
third party image
Courtesy of Bob M. here's a diagram for you.
