? About 300 Or 300 utility motor parts.
MagMan
09-25-2004 12:47:06
Is a 300 utility as far as new intake manifold the same as the H, SH, 300,350 . And how do they say a manifold will fit a H or SH when they have different carbs? JON
Ibby
09-26-2004 04:56:30
 Re: ? About 300 Or 300 utility motor parts. in reply to MagMan, 09-25-2004 12:47:06
I put an H manifold on my 350 utility (with a 300 engine) It does exit up thru the hood, but I was able to find a Diesal Industrial hood on eBay with a factory opening in the right place. My existing carb bolted right up to it.
The original utilities had an elbow between the manifold and exhaust pipe that could be turned up to exhaust out the hood. The parts manual shows where to cut the hole
DWV
09-25-2004 17:09:39
If you want to run exhaust up through hood they
will interchange.Some of the aftermarket manifolds
have slotted carb mounting holes so both carbs will work using bolts.
MagMan
09-25-2004 17:43:29
 Re: ? About 300 Or 300 utility motor parts. in reply to DWV, 09-25-2004 17:09:39
So I take it that the utility has a exuast that goes down and not up?
big fred
09-25-2004 18:26:43
 Re: ? About 300 Or 300 utility motor parts. in reply to MagMan, 09-25-2004 17:43:29
On the 300U, a down was standard, an up was an option, though I"ve never seen one. It shows in the parts books though.
