H somkes
k_ b in md
09-25-2004 15:09:42
1940 H ran good all summer raking hay pulling wagons ect. yesterday with no load it started to smoke light black like it was choked, turned heavier black, runnning out power shut it off right away. towed to barn, it's starts black smoke shuts off in after a minute. any ideas where to start. thanks for the help
EricB
09-27-2004 09:35:12
 Re: H somkes in reply to k_ b in md, 09-25-2004 15:09:42
Everyone is pointing to carberator. Hate to suggest it but do a compression test. My first thought would be stuck valve or split ring.
mark k
09-25-2004 19:21:43
Hello,
You might even want to have it running with smoke and turn off the fuel and see if it smooths out within about 30 sec then runs well until it runs out of fuel in the carb. If it does then the carb is where the problem is. Mark
James Williams
09-25-2004 18:37:05
Sounds like a leaky float,Remove the float,and shake it you should not have any gas inside the float
Boyd
09-25-2004 16:56:10
As a last resort you might check the air filter. Boyd
Allan in NE
09-25-2004 23:41:28
 Re: H somkes in reply to Boyd, 09-25-2004 16:56:10
Hi Boyd,
H's don't have air filters; they have air cleaners.
Allan
rustyfarmall
09-25-2004 15:31:48
Might have got a speck of rust or something into the carb and it's lodged in the needle valve and seat, allowing fuel to trickle in all the time. Probably have to take the carb apart to remedy it.
Red Dread
09-25-2004 15:25:14
Sound"s like a fuel delivery problem. Check the float setting in the carb for starters.
