350 Utility hyd pump
mark k
09-25-2004 20:18:59
Hello,
I was wondering if a 400 or 450 pump will work on my 350 U. I looked at some used ones the other day and the 400, 450 pump output down, my 350 goes back to the rear of the tractor. Some of the tractors I saw at the fair had something like an adapter on there pumps that output down it directed the tubing or hoze to the back. It is a square block that bolts on the pump and has fittings that connect to the hoze or tubing. Thanks Mark
Ibby
09-26-2004 04:43:21
 Re: 350 Utility hyd pump in reply to mark k, 09-25-2004 20:18:59
I've seen hoses hook to the 300/350 2 different ways. Some turn up at a 90 degree angle and bolt directly to the pump. Others (like mine) have the rectangular block you mention, and the hoses attach straight in to it. I don't know, but suspect it may have something to do with whether or not the tractor originally came equipped with power steering.
I don't believe the 400/450 pump will fit. It has a larger output and looks slightly bigger overall.
