oil in model m
bob in texas
09-26-2004 06:37:22
My M has been setting for quite awhile. Started putting oil in and so far have added 9 quarts. Still has not run out of bottom indicator on left side. It is only supposed to hold 7 quarts, right? So-where is it going?
El Toro
09-26-2004 13:41:52
 Re: oil in model m in reply to bob in texas, 09-26-2004 06:37:22
Run a piece of wire through the petcocks. Hal
CNKS
09-26-2004 11:32:28
umm-the indicators are on the right side.
The Red
09-26-2004 12:25:27
 Re: oil in model m in reply to CNKS, 09-26-2004 11:32:28
They are on the left if you are standing in front of the tractor looking at the Farmall emblem, LOL
Bubba
09-26-2004 09:25:51
Your M holds 8 qts of oil. check your drain cocks. Are they pluged up?
The Red
09-26-2004 09:06:05
With 9 quarts, open the top oil gauge valve. Bet oil will stream out.
El Toro
09-26-2004 07:17:00
Hi Bob, I would check that bottom indicator to be sure that it isn't plugged with sludge or dirt.
My IH manual has the oil capacity at 8 quarts for a Farmall M. Hal
