Farmall 544 utility
Chad L.
09-26-2004 07:08:53
I am looking for a tractor to pull a 2 or 3 bottom plow, run a 4 row cornplanter etc.. i would only have 5 acres or so max to plant so i would not be using the tractor for many hours in the field. I recently saw a farmall 544 utility gas tractor for that has the 13.6?x28 inch rear tires. Would this be a good tractor to plow and plant with or is it too small and without enough clearance? Also on the side would chains be necessary to have if i used it for snow removal. By the way the tires are new, and not loaded. Or could i just load the tires and that would be good enough for winter use?
CNKS
09-26-2004 11:18:21
 Re: Farmall 544 utility in reply to Chad L., 09-26-2004 07:08:53
The tractor is ok for your intended use, perhaps a bit large for only 5 acres. It should easily handle a three bottom plow, a 4-row planter is no problem. It does not have a lot of clearance, which means you wouldn't be able to do late cultivation, but depening on your weed situation that may be ok. Calcium chloride is hard on rims if it leaks, otherwise you can use wheel weights for snow.
