Rear Axel Seals M
Richard Fazio
09-27-2004 06:19:19
The rear axel seals are leaking on my 48 M. I ordered the seals and finally got the rear wheels off. So I pulled off the first seal cover and the new seals I got are different from the originals. The originals have a rubber seal with a steel back on it. Then there is a felt pad sqeezed between the steel back of the seal and the retainer cover. the new seal is like a normal bearing seal. Even if I had the felt it wouldn't work cause the seal doesn't have the steel back on it to hold the felt. Did I get the wrong seal or is this the new type? Do I still use the felt? Thanks in advance for any advice.
CNKS
09-27-2004 07:29:12
 Re: Rear Axel Seals M in reply to Richard Fazio, 09-27-2004 06:19:19
If you ordered IH seals, or your supplier crossed them properly they are correct. Case-IH still has the felt, you need that too. I'm confused about the steel back. Yours has to have it, but it may be on only one, not both sides -- that's ok. Install the seal with the lip facing the oil flow (in towards the tractor). Before you do that install a new felt in the end cap. It will be held by the metal back of the seal.
Richard Fazio
09-27-2004 08:01:30
 Re: Rear Axel Seals M in reply to CNKS, 09-27-2004 07:29:12
Thanks for the responce. The seals that were on there looked like the lip was out? If I put the lip in toward the oil the the steel face of the seal would be up against the felt. I guess that would be ok. I didn't know i needed the felt, I guess I should order that also. What is the felt for, to keep dirt out of the seal? The other thing I was wondering is why is there a grease fitting on the housing? The axel bearing is oiled by the transmission oil.
CNKS
09-27-2004 11:23:21
 Re: Rear Axel Seals M in reply to Richard Fazio, 09-27-2004 08:01:30
It's a dust seal. I imagine the grease zerk is there to grease the seal and keep it from drying out? Some of the later models with the same arrangement don't have a grease fitting. The lip of the seal goes toward the tractor, the flat surface goes against the felt. OR--With the cap laying on it's back (the side that goes toward the wheel), put in the felt then drive in the seal with the lip facing up.
