Farmall Super C with leaking tom water spout
Scott Swanson
09-27-2004 09:38:16
Filler neck on my 1951 Super C leaks under pressure. What are my options? Can I run it without pressure? Would my performance suffer much?
Any thoughts?
Thanks!
Wayne Swenson
09-27-2004 21:27:04
 Re: Farmall Super C with leaking tom water spout in reply to Scott Swanson, 09-27-2004 09:38:16
Take the radiator to a repair shop and get the job done right.
achodges1
09-27-2004 20:52:48
If you have a working temp gauge you can run without a cap. You will still need to check and add water often. and antifreeze as well depending on conditions. JB weld might be a cheap fix for the neck.
