Old Plow
Allan in NE
09-27-2004 15:57:32
Hi All,
I finally found the plow I want except the dealer wants $700 more for it than I gave for a brand new one 30 years ago.
What gives with that deal? :>(
third party image
scotty
09-28-2004 05:08:11
 Re: Old Plow in reply to Allan in NE, 09-27-2004 15:57:32
OK Allan, Im not afraid to ask how that thing works? Not a farmer, just guessing that that trail wheel is hydraulically operated to raise and lower the main beam and some how at the end of the field the whole thing rotates at the pull or pivot point for the opposite hand plow? Is that anywhere close to being right?
Thanks.
scotty
Allan in NE
09-28-2004 05:52:07
 Re: Old Plow in reply to scotty, 09-28-2004 05:08:11
Mornin" Scotty,
The whole she-bang is 3-point mounted, of course and is built in two pieces: The hitch has a large diameter barrel that the main plow backbone rides on.
If you will notice in the picture, there is a hydraulic cylinder laying crosswise on top of the hitch frame right behind and above the lower hitch points. This cylinder is tied to both the hitch and the main plow frame.
When the cylinder is actuated, the whole mess rotates laterally 180 degrees on this large barrel and it always rotates in a direction whereby that gauge wheel will swing down underneath the plow as it rotates.
This swinging motion of the spin allows gravity to unlock a somewhat large "rocking" lock at the gauge wheel and will then let the gauge wheel drop down onto it"s opposite catch as the plow is coming up into the opposite pull direction.
The sequence is: lift the 3-point at the end of the field, do a tight braking figure-8 turn out onto the unplowed ground while at the same time spinning the plow over for the next run. The whole complete spin of the plow probably doesn"t take 3 to 5 seconds.
Hope this makes sense, I"m only on my first cup. :>)
Allan
scotty
09-28-2004 06:27:08
 Re: Old Plow in reply to Allan in NE, 09-28-2004 05:52:07
Thanks Allan, Something tells me my 32HP Massey Diesel 4x4 aint gonna pull that monster even though it says Massey!!! Have a good day!
scotty
Allan in NE
09-28-2004 06:51:29
 Re: Old Plow in reply to scotty, 09-28-2004 06:27:08
Scotty,
I've got a 60 horse outfit that "might" lift it & move it across the yard, hence the overwhelming need for that 966 I'm so desperately searching for. :>)
Isn't this old iron fun? But hey! Why doesn't my banker wanna talk to me anymore? Geeze! I just don't get it! He's got no sense of humor at all.... :>)
Allan
Matt K.
09-27-2004 18:18:17
Around here plows go pretty cheap (central michigan)
I saw a JD 6 bottom spring reset go for $440.00 at
auction last winter,it was real nice.They could hardly get anyone to bid on it.We got a 5 bottom
international semi-mount for $50.00 a couple years ago,all it needs is two new moldboards to be field
ready.There are very few plows in the field anymore
in our area,mostly all disc-chisels.Dad still likes
to plow down june clover & corn stubble.
rustyfarmall
09-27-2004 18:01:39
Allen, how do I put this? I can see that the plow is red and all that, but, well, you see, oh well, I'll go ahead and say it, it is not an IH. There, I said it, and I feel a lot better.
Allan in NE
09-27-2004 18:13:30
 Re: Old Plow in reply to rustyfarmall, 09-27-2004 18:01:39
Rusty,
Ever hooked on to one of those IH spinners? :>)
These Masseys will pull wayyyyy yyy easier. Promise. (But, I think you already knew that) :>)
Allan
rustyfarmall
09-27-2004 18:20:14
 Re: Old Plow in reply to Allan in NE, 09-27-2004 18:13:30
Actually, I've never had any experience with any of the spinner type plows. They just weren't used around here.
Allan in NE
09-27-2004 20:46:42
 Re: Old Plow in reply to rustyfarmall, 09-27-2004 18:20:14
Rusty,
When the wife and I get this hobby venture of ours all put together, I want ya to swing by out this way if it is at all possible (don't know where ya live) and give this type plow a try.
You'll just eat it up!
Allan
Nebraska Cowman
09-27-2004 17:02:46
Oh shoot just wait til this winter...stand around at farm sales all day long freezing your butt off and buy that same plow for $350. Is it worth it?
Allan in NE
09-27-2004 19:12:36
 Re: Old Plow in reply to Nebraska Cowman, 09-27-2004 17:02:46
NC,
Yep, it's hard for me to even think about that day so many years ago, but that is exactly how I lost the first one.
I think mine brought a screamin' $500 if I remember right.
This thread is going in the wrong direction..... .. :>(
Allan
farmallman
09-27-2004 16:48:58
What kind of plow is that?
Allan in NE
09-27-2004 17:49:08
 Re: Old Plow in reply to farmallman, 09-27-2004 16:48:58
Hi,
It is a Massey. 4 18 inch bottoms.
Allan
farmallman
09-27-2004 17:53:19
 Re: Old Plow in reply to Allan in NE, 09-27-2004 17:49:08
What do u pull it with?
Allan in NE
09-27-2004 18:08:25
 Re: Old Plow in reply to farmallman, 09-27-2004 17:53:19
Hi Farmallman,
It takes about a 100 horse tractor to pull one of these things nicely; they are one heck of a plow and the thing I like about the Masseys is that they do pull so easy as compared to some of the other brands.
Allan
farmallman
09-27-2004 18:11:58
 Re: Old Plow in reply to Allan in NE, 09-27-2004 18:08:25
OK. But what do u personally have to pull it
Allan in NE
09-27-2004 18:22:07
 Re: Old Plow in reply to farmallman, 09-27-2004 18:11:58
I haven't got a darned thing that will pull it..... ....(yet). :>)
Got lots of hurdles to jump before I can even start to think about buying the plow (the wife and I are still workin' on the darned dirt deal).
Allan
caseyc
09-27-2004 19:42:18
 Re: Old Plow in reply to Allan in NE, 09-27-2004 18:22:07
i see i"m not the only one!!! i can never resist a piece of equipment that i know i"ll need some day when i get more land bought! still having a tough time getting the wife to see it that way though. """honey, it"s a great deal and that way i"ll have it when i get more land. if i let it go then i"ll get more land and i won"t have the equipment to work it!""" who am i kidding, it only works sometimes.
Allan in NE
09-27-2004 20:11:49
 Re: Old Plow in reply to caseyc, 09-27-2004 19:42:18
Casey,
There are days when I think I am totally crazy; but I guess you gotta jump when the jumpin' is good.
10 days ago, I bought this darned IH disc and haven't even got the farm bought yet.
How dumb is that? :>)
Oh well, it's gonna happen all in good time.
Allan
third party image
farmallman
09-27-2004 18:30:20
I see
Dick Davis
09-28-2004 00:32:54
 Re: Old Plow in reply to farmallman, 09-27-2004 18:30:20
No you don't see, you're just trying to encourage his behavior. LOL
farmallman
09-28-2004 05:11:51
 Re: Old Plow in reply to Dick Davis, 09-28-2004 00:32:54
Yes. is "I understand" better???
Dick Davis
09-28-2004 07:27:06
 Re: Old Plow in reply to farmallman, 09-28-2004 05:11:51
Yes
