OT, bosch injector pump on a truck?
Chris Brown
09-27-2004 17:14:28
Does anyone know how to turn up the rpm"s on a "P" series bosch pump on a 94 ford L8000 truck. Theres a funny looking stop screw with no head, I assume it is the adjustment,at least it would be on a tractor pump.
KEV
09-27-2004 18:47:29
 Re: OT, bosch injector pump on a truck? in reply to Chris Brown, 09-27-2004 17:14:28
There is a screw on the outside of the pump, you will need a 10mm wwrench and a o-ring pick.
The screw is located twords the back of the pump by the throttle lever.Probably sealed by a wire or may have a protective cap over it.
any other questions call me.(763)971-4882
Thank you
KEV
Chris Brown
09-28-2004 17:23:54
 Re: OT, bosch injector pump on a truck? in reply to KEV, 09-27-2004 18:47:29
Thanks Kev. The cap is what had me fooled.There is paint on it and it looked like the plastic cap was part of the screw. I just want to give it a couple hundred rpms,55 mph sucks all day long.And I know it will do more than 2000 rpm,2500 won't hurt it any.
