hydraulic oil or motor oil for the pump
cj
09-28-2004 04:59:24
I have a H that I was using hydraulic oil for the pump. A friend told me that I should use SAE 30 motor oil. I"m getting ready to drain it and would like to know what i should put back in
CNKS
09-28-2004 18:32:24
 Re: hydraulic oil or motor oil for the pump in reply to cj, 09-28-2004 04:59:24
As noted below, if you are using a pull-behind implement with another tractor, use hytran, or better use the same hyd oil as is in the other tractor, if it is not IH. Your system is not picky about the oil it uses. A disadvantage with Hytran is that it is thinner, and will tend to leak more if the seals are worn. If it is your only tractor, I would just stick with SAE 30 non-detergent.
John in NE
09-28-2004 05:53:26
I use 30weight hydraulic oil in mine,it works just fine above 40.It takes a little time to warm it up when its cold,but so do I.John.
Nebraska Cowman
09-28-2004 05:32:17
That is the old way but I would use Hy-tran. Modern hydraulic oils were not available when the lift-all pump was designed but are a much better substitute now.
JW
09-28-2004 05:58:56
 Re: hydraulic oil or motor oil for the pump in reply to Nebraska Cowman, 09-28-2004 05:32:17
Hy-Tran is not thick enough, after the oil gets good and warm it has a tendacy to bypass if you are trying to lift anything with much wieght to it at all. I learned that the hard way and went back to 30wt, like the lift-all manual suggests.
MarkO
09-28-2004 10:33:19
 Re: hydraulic oil or motor oil for the pump in reply to JW, 09-28-2004 05:58:56
I have had this question for a while. If you use an implement on two tractors, one with 30W and one with Hy-Tran, won't the fluids become contaminated?
Dave in CT
09-28-2004 10:47:21
 Re: hydraulic oil or motor oil for the pump in reply to MarkO, 09-28-2004 10:33:19
Yeah, that's another reason to use Hy-Trans. Make sure if you use 30W that it is non-detergent. I've heard that the detergent oil foams in the hydraulic system. I started with 30W non-det. in my '47 H but switched to Hy-Trans, which worked great and am now using just Hydraulic oil which is a little thinner. I think I'll settle on the Hy-Trans which can be gotten inexpensively from Wal-Mart. I've used the Hy-Trans on a single 3.5" x 8" cylinder to lift a 12' x 15" oak log and I didn't experience any problem - FWIW.
Rich Griffin
09-28-2004 05:15:28
30w non detergent motor oil for summer use,10w nondetergent for winter use.
